本人使用centos7.2系统最小化安装,安装好系统之后配置好mysql,按照手册RHEL/CentOS 系统方法 2配置开机自动启动文件后,服务开机不能自动启动,但是手动可以启动服务,请问下如何解决。
[root@data data]# systemctl status seafile
● seafile.service - SYSV: seafile
Loaded: loaded (/etc/rc.d/init.d/seafile)
Active: failed (Result: exit-code) since Mon 2016-09-26 01:36:33 CST; 38min ago
Docs: man:systemd-sysv-generator(8)
Process: 1433 ExecStart=/etc/rc.d/init.d/seafile start (code=exited, status=1/FAILURE)
Sep 26 01:36:33 data systemd[1]: Starting SYSV: seafile…
Sep 26 01:36:33 data su[1434]: (to root) root on none
Sep 26 01:36:33 data seafile[1433]: Starting seafile:
Sep 26 01:36:33 data systemd[1]: seafile.service: control process exited, code=exited status=1
Sep 26 01:36:33 data systemd[1]: Failed to start SYSV: seafile.
Sep 26 01:36:33 data systemd[1]: Unit seafile.service entered failed state.
Sep 26 01:36:33 data systemd[1]: seafile.service failed.
[root@data data]# systemctl status seahub
● seahub.service - SYSV: seahub
Loaded: loaded (/etc/rc.d/init.d/seahub)
Active: failed (Result: exit-code) since Mon 2016-09-26 01:36:41 CST; 38min ago
Process: 1479 ExecStart=/etc/rc.d/init.d/seahub start (code=exited, status=203/EXEC)
Sep 26 01:36:41 data systemd[1]: Starting SYSV: seahub…
Sep 26 01:36:41 data systemd[1]: seahub.service: control process exited, code=exited status=203
Sep 26 01:36:41 data systemd[1]: Failed to start SYSV: seahub.
Sep 26 01:36:41 data systemd[1]: Unit seahub.service entered failed state.
Sep 26 01:36:41 data systemd[1]: seahub.service failed.
[root@data data]# tree /data -L 2
目录结构如下
/data
├── ccnet
│ ├── ccnet.sock
│ ├── misc
│ ├── mykey.peer
│ └── seafile.ini
├── conf
│ ├── ccnet.conf
│ ├── seafdav.conf
│ ├── seafile.conf
│ ├── seahub_settings.py
│ └── seahub_settings.pyc
├── installed
│ └── seafile-server_5.1.4_x86-64.tar.gz
├── logs
│ ├── ccnet.log
│ ├── controller.log
│ ├── seafile.init.log
│ ├── seafile.log
│ ├── seahub_django_request.log
│ └── seahub.log
├── pids
│ ├── ccnet.pid
│ └── seaf-server.pid
├── seafile-data
│ ├── commits
│ ├── fs
│ ├── httptemp
│ ├── library-template
│ ├── storage
│ └── tmpfiles
├── seafile-server-5.1.4
│ ├── check_init_admin.py
│ ├── reset-admin.sh
│ ├── runtime
│ ├── seaf-fsck.sh
│ ├── seaf-fuse.sh
│ ├── seaf-gc.sh
│ ├── seafile
│ ├── seafile.sh
│ ├── seahub
│ ├── seahub.sh
│ ├── setup-seafile-mysql.py
│ ├── setup-seafile-mysql.sh
│ ├── setup-seafile.sh
│ └── upgrade
├── seafile-server-latest -> seafile-server-5.1.4
└── seahub-data
└── avatars
21 directories, 27 files
所有的文件默认在/data 目录下,因操作系统在一个32G 的固态盘上安装,/data 目录实际上是一个挂载了一块4T硬盘的目录。
创建/etc/sysconfig/seafile文件的时候,只是修改了手册中默认的seafile_dir=/home/haiwen
为如下内容
seafile_dir=/data
script_path=${seafile_dir}/seafile-server-latest
