RT
terminal客户端出现Failed to update branch of xxxx
Repo ‘xxx’ sync state transition from uploading to ‘error’:‘Error occured inupload’
Failed to calculate fs object list from repo xxx
RT
把更完整的日志贴一下吧。你用的是什么版本的客户端和服务器?客户端和服务器分别是什么操作系统?
[04/01/17 06:30:13] sync-mgr.c(660): Repo ‘xxxx’ sync state transition from ‘synchronized’ to ‘uploading’.
[04/01/17 06:30:13] http-tx-mgr.c(3074): Upload with HTTP sync protocol version 1.
[04/01/17 06:30:13] http-tx-mgr.c(950): Transfer repo ‘691d2e82’: (‘normal’, ‘init’) --> (‘normal’, ‘check’)
[04/01/17 06:30:13] http-tx-mgr.c(950): Transfer repo ‘691d2e82’: (‘normal’, ‘check’) --> (‘normal’, ‘commit’)
[04/01/17 06:30:13] http-tx-mgr.c(950): Transfer repo ‘691d2e82’: (‘normal’, ‘commit’) --> (‘normal’, ‘fs’)
[04/01/17 06:30:13] http-tx-mgr.c(3120): Failed to calculate fs object list for repo 691d2e82.
[04/01/17 06:30:13] http-tx-mgr.c(950): Transfer repo ‘691d2e82’: (‘normal’, ‘fs’) --> (‘error’, ‘finished’)
[04/01/17 06:30:13] sync-mgr.c(728): Repo ‘xxxx’ sync state transition from uploading to ‘error’: ‘Error occured in upload.’.
服务器版本:5.1.2 所在系统centos
客户端版本: 4.3.2 所在系统Ubuntu
[04/05/17 09:43:07] sync-mgr.c(660): Repo ‘Version’ sync state transition from ‘synchronized’ to ‘uploading’.
[04/05/17 09:43:07] http-tx-mgr.c(3074): Upload with HTTP sync protocol version 1.
[04/05/17 09:43:07] http-tx-mgr.c(950): Transfer repo ‘ad0db16d’: (‘normal’, ‘init’) --> (‘normal’, ‘check’)
[04/05/17 09:43:07] http-tx-mgr.c(950): Transfer repo ‘ad0db16d’: (‘normal’, ‘check’) --> (‘normal’, ‘commit’)
[04/05/17 09:43:07] http-tx-mgr.c(950): Transfer repo ‘ad0db16d’: (‘normal’, ‘commit’) --> (‘normal’, ‘fs’)
[04/05/17 09:43:07] http-tx-mgr.c(3120): Failed to calculate fs object list for repo ad0db16d.
[04/05/17 09:43:07] http-tx-mgr.c(950): Transfer repo ‘ad0db16d’: (‘normal’, ‘fs’) --> (‘error’, ‘finished’)
[04/05/17 09:43:07] sync-mgr.c(728): Repo ‘Version’ sync state transition from uploading to ‘error’: ‘Error occured in upload.’.
[04/05/17 09:43:08] sync-mgr.c(660): Repo ‘Version’ sync state transition from ‘synchronized’ to ‘uploading’.
[04/05/17 09:43:08] http-tx-mgr.c(3074): Upload with HTTP sync protocol version 1.
[04/05/17 09:43:08] http-tx-mgr.c(950): Transfer repo ‘2ab9d72e’: (‘normal’, ‘init’) --> (‘normal’, ‘check’)
[04/05/17 09:43:08] http-tx-mgr.c(950): Transfer repo ‘2ab9d72e’: (‘normal’, ‘check’) --> (‘normal’, ‘commit’)
[04/05/17 09:43:08] http-tx-mgr.c(950): Transfer repo ‘2ab9d72e’: (‘normal’, ‘commit’) --> (‘normal’, ‘fs’)
[04/05/17 09:43:08] http-tx-mgr.c(950): Transfer repo ‘2ab9d72e’: (‘normal’, ‘fs’) --> (‘normal’, ‘data’)
[04/05/17 09:43:08] http-tx-mgr.c(950): Transfer repo ‘2ab9d72e’: (‘normal’, ‘data’) --> (‘normal’, ‘update-branch’)
[04/05/17 09:43:08] http-tx-mgr.c(2980): Bad response code for PUT https://[–ip–]/seafhttp/repo/2ab9d72e-be98-4ec3-9032-eb7fed55db6c/commit/HEAD/?head=dbb5cd50be869d0f4ff0cd537e3c860e1b146d73: 500.
[04/05/17 09:43:08] http-tx-mgr.c(3197): Failed to update branch of repo 2ab9d72e.
[04/05/17 09:43:08] http-tx-mgr.c(950): Transfer repo ‘2ab9d72e’: (‘normal’, ‘update-branch’) --> (‘error’, ‘finished’)
[04/05/17 09:43:08] sync-mgr.c(728): Repo ‘Version’ sync state transition from uploading to ‘error’: ‘Error occured in upload.’.
[04/05/17 09:54:32] http-tx-mgr.c(784): libcurl failed to PUT https://[–ip–]/seafhttp/repo/5f20123d-40a3-4e38-90ff-76e20bc61929/block/b68980aeff4ea0d34350c7a6024472a98b442d4e: Timeout was reached.
[04/05/17 09:54:32] http-tx-mgr.c(784): libcurl failed to PUT https://[–ip–]/seafhttp/repo/5f20123d-40a3-4e38-90ff-76e20bc61929/block/6b612400ddfe1025ceef9f24b8a6bdbfcfa79db5: Operation was aborted by an application callback.
[04/05/17 09:54:32] http-tx-mgr.c(784): libcurl failed to PUT https://[–ip–]/seafhttp/repo/5f20123d-40a3-4e38-90ff-76e20bc61929/block/3e4f2359a66e613c712657b4e110d13bfa4c1efb: Operation was aborted by an application callback.
[04/05/17 09:54:33] http-tx-mgr.c(784): libcurl failed to PUT https://[–ip–]/seafhttp/repo/5f20123d-40a3-4e38-90ff-76e20bc61929/block/dbf933cb682709d41c44c87bca606c8d69f98934: Operation was aborted by an application callback.
[04/05/17 09:54:33] http-tx-mgr.c(784): libcurl failed to PUT https://[–ip–]/seafhttp/repo/5f20123d-40a3-4e38-90ff-76e20bc61929/block/a2c9e3952dd00dc7ddae7e20992d30d22823db5f: Operation was aborted by an application callback.
[04/05/17 09:54:33] http-tx-mgr.c(784): libcurl failed to PUT https://[–ip–]seafhttp/repo/5f20123d-40a3-4e38-90ff-76e20bc61929/block/97760563cea86d38e3da7e844cdd05ed9242d175: Operation was aborted by an application callback.
[04/05/17 09:54:33] http-tx-mgr.c(784): libcurl failed to PUT https://[–ip–]/seafhttp/repo/5f20123d-40a3-4e38-90ff-76e20bc61929/block/b11324f8e2db0708a2278d29bae5de8c58c55cd7: Operation was aborted by an application callback.
[04/05/17 09:54:33] http-tx-mgr.c(784): libcurl failed to PUT https://[–ip–]/seafhttp/repo/5f20123d-40a3-4e38-90ff-76e20bc61929/block/6196c74aee405ddf1a279970209bdd8269b99b0a: Operation was aborted by an application callback.
[04/05/17 09:54:33] sync-mgr.c(660): Repo ‘Version’ sync state transition from ‘synchronized’ to ‘uploading’.
客户端版本太老了,升级到最新版吧。
首先感谢回复。
当我直接升级到新版的时候,重启客户端,仍会报此异常。
然后desync----重新init----sync,目前已经可以正常同步。
