[root@localhost seafile-server-latest]# ./seahub.sh start-fastcgi
Warning: Cache is not working, please check memcached is running if you are using memcached backend, otherwise, please check permission of cache directory on your file system.
Seahub is started
Done.
以下是logs/seahub.log文件内容:
2017-08-03 08:01:28,200 [ERROR] django.pylibmc:146 set MemcachedError: error 3 from memcached_set: CONNECTION FAILURE
File “/usr/lib/python2.7/site-packages/django_pylibmc/memcached.py”, line 140, in set
**COMPRESS_KWARGS)
ConnectionError: error 3 from memcached_set: CONNECTION FAILURE
2017-08-03 08:01:28,201 [ERROR] django.pylibmc:132 get MemcachedError: error 47 from memcached_get(:1:test_cache): SERVER HAS FAILED AND IS DISABLED UNTIL TIMED RETRY
File “/usr/lib/python2.7/site-packages/django_pylibmc/memcached.py”, line 130, in get
return super(PyLibMCCache, self).get(key, default, version)
File “/home/user/haiwen/seafile-server-6.1.1/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/cache/backends/memcached.py”, line 84, in get
val = self._cache.get(key)
ServerDown: error 47 from memcached_get(:1:test_cache): SERVER HAS FAILED AND IS DISABLED UNTIL TIMED RETRY
2017-08-03 08:31:05,059 [ERROR] django.pylibmc:146 set MemcachedError: error 3 from memcached_set: CONNECTION FAILURE
**COMPRESS_KWARGS)
2017-08-03 08:31:05,060 [ERROR] django.pylibmc:132 get MemcachedError: error 47 from memcached_get(:1:test_cache): SERVER HAS FAILED AND IS DISABLED UNTIL TIMED RETRY
2017-08-03 08:46:41,275 [ERROR] django.pylibmc:146 set MemcachedError: error 3 from memcached_set: CONNECTION FAILURE
**COMPRESS_KWARGS)
2017-08-03 08:46:41,276 [ERROR] django.pylibmc:132 get MemcachedError: error 47 from memcached_get(:1:test_cache): SERVER HAS FAILED AND IS DISABLED UNTIL TIMED RETRY
