症状:浏览器输入我的域名出现502 Bad Gateway,浏览器地址栏显示安全(我用的是火狐地址前面绿色)
求问哪里不对,另外如果还需要什么信息请说,以及win版感觉人很少姑且直接发服务器问题版块好了……
使用版本:
seafile-server_6.0.7_win32.tar.gz
nginx-1.12.0.zip
python-2.7.13.msi
cn_windows_server_2016_x64
其他使用:
域名购买自阿里云,顺带使用了阿里云 云解析DNS
seafile设置(网页上设置的):
SERVICE_URL https://隐藏了我的域名
FILE_SERVER_ROOT https://隐藏了我的域名/seafhttp
seahub.error.log如下
[error] 3268#4592: *4 upstream sent unsupported FastCGI protocol version: 72 while reading response header from upstream, client: 192.168.1.1, server: 我的域名这里就手动隐藏了, request: “GET / HTTP/2.0”, upstream: “fastcgi://127.0.0.1:8000”, host: “我的域名这里就手动隐藏了”
下面是nginx.conf
worker_processes auto;
events {
worker_connections 1024;
http {
include mime.types;
listen 80;
server_name 这里隐藏了我的域名;
rewrite ^(.*) https://$server_name$1 permanent; # force redirect http to https
listen 443 http2;
ssl on;
ssl_certificate C:/cert/阿里云证书同样隐藏.pem;
ssl_certificate_key C:/cert/阿里云证书同样隐藏.key;
ssl_session_timeout 5m;
ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE:ECDH:AES:HIGH:!NULL:!aNULL:!MD5:!ADH:!RC4;
ssl_prefer_server_ciphers on;
server_tokens off;
fastcgi_pass 127.0.0.1:8000;
fastcgi_param HTTPS on;
access_log logs/seahub.access.log;
error_log logs/seahub.error.log;
fastcgi_read_timeout 36000;
proxy_request_buffering off;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
root C:/SeafileProgram/seafile-server-6.0.7/seahub;
