如题,想修改Nginx配置文件,却找了好久没找到:sweat:
另外参照示例,我需要改动的地方有哪些?
手册示例如下:
listen 80;
server_name www.yourdoamin.com;
rewrite ^ https://$http_host$request_uri? permanent; #强制将http重定向到https
listen 443;
ssl on;
ssl_certificate /etc/ssl/cacert.pem; #cacert.pem 文件路径
ssl_certificate_key /etc/ssl/privkey.pem; #privkey.pem 文件路径
fastcgi_pass 127.0.0.1:8000;
fastcgi_param HTTPS on;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
root /home/user/haiwen/seafile-server-latest/seahub;
