配置nginx访问seafile web端始终无法访问
服务都重启了都没有问题 ,以fastcgi模式启动的,nginx也没有报错。配置的域名是pan.xxx.cn,然后现在访问都会自动访问xxx.cn的页面 不知道为何。下面放上nginx.conf 和虚拟主机配置文件
虚拟主机:
listen 80;
server_name pan.xxx.cn; #这里需要改成你的域名或IP
     fastcgi_param    SERVER_ADDR         $server_addr;
     fastcgi_param    SERVER_PORT         $server_port;
     fastcgi_param    SERVER_NAME         $server_name;
     access_log      /data/wwwlogs/seahub.access.log;
     error_log       /data/wwwlogs/seahub.error.log;
     proxy_read_timeout  36000s;
     root /xxx/seahub/; #这里需要改成你的 seafile-server-latest 所在的目录,例如 /home/user/seafile-server-latest/seahub
nginx配置文件
user www www;
worker_processes auto;
error_log /data/wwwlogs/error_nginx.log crit;
pid /var/run/nginx.pid;
worker_rlimit_nofile 51200;
 events {
   use epoll;
   worker_connections 51200;
   multi_accept on;
 http {
   include mime.types;
   server_names_hash_bucket_size 128;
   client_header_buffer_size 32k;
   large_client_header_buffers 4 32k;
   client_max_body_size 1024m;
   client_body_buffer_size 10m;
   sendfile on;
   tcp_nopush on;
   keepalive_timeout 120;
   server_tokens off;
   tcp_nodelay on;
   fastcgi_connect_timeout 300;
   fastcgi_send_timeout 300;
   fastcgi_read_timeout 300;
   fastcgi_buffer_size 64k;
   fastcgi_buffers 4 64k;
   fastcgi_busy_buffers_size 128k;
   fastcgi_temp_file_write_size 128k;
   fastcgi_intercept_errors on;
   #Gzip Compression
   gzip on;
   gzip_buffers 16 8k;
   gzip_comp_level 6;
   gzip_http_version 1.1;
   gzip_min_length 256;
   gzip_proxied any;
   gzip_vary on;
   gzip_types
     text/xml application/xml application/atom+xml application/rss+xml application/xhtml+xml image/svg+xml
 text/javascript application/javascript application/x-javascript
     text/x-json application/json application/x-web-app-manifest+json
     text/css text/plain text/x-component
     font/opentype application/x-font-ttf application/vnd.ms-fontobject
     image/x-icon;
   gzip_disable "MSIE [1-6]\.(?!.*SV1)";
   #If you have a lot of static files to serve through Nginx then caching of the files' metadata (not the actual files' contents) can save some latency.
   open_file_cache max=1000 inactive=20s;
   open_file_cache_valid 30s;
   open_file_cache_min_uses 2;
   open_file_cache_errors on;
 ######################## default ############################
     listen 80;
     server_name xxx.cn;
     access_log /data/wwwlogs/access_nginx.log combined;
     root /data/wwwroot/default;
     index index.html index.htm index.php;
     #error_page 404 /404.html;
     #error_page 502 /502.html;
     location /nginx_status {
       stub_status on;
       access_log off;
       allow 127.0.0.1;
       deny all;
     location ~ [^/]\.php(/|$) {
       #fastcgi_pass remote_php_ip:9000;
       fastcgi_pass unix:/dev/shm/php-cgi.sock;
       fastcgi_index index.php;
       include fastcgi.conf;
     location ~ .*\.(gif|jpg|jpeg|png|bmp|swf|flv|mp4|ico)$ {
       expires 30d;
       access_log off;
 location ~ .*\.(js|css)?$ {
   expires 7d;
   access_log off;
 location ~ /\.ht {
   deny all;
include vhost/*.conf;
论坛默认将你的代码用 markdown 解析了。发代码块的时候用三个 数字1左边的```,来引用代码例如
我是代码
你Nginx的配置有问题。建议给seafile单独一台服务器,然后使用一键安装脚本装seafile
