我在windows2003上面安装的
可以正常登录。
登录管理员后,点击资料库或者点击设置
就出现如下的错误,有谁知道是什么原因吗
查看一下 服务器 log 中有什么错误信息吗?主要是 seahub_django_request.log
2016-12-02 10:39:26,953 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /sys/seafadmin/
File “E:\SeafileProgram\seafile-server-5.1.3\seahub\thirdpart\django-1.8.10-py2.7.egg\django\core\handlers\base.py”, line 132, in get_response
File “E:\SeafileProgram\seafile-server-5.1.3\seahub\seahub\auth\decorators.py”, line 26, in _wrapped_view
File “E:\SeafileProgram\seafile-server-5.1.3\seahub\seahub\base\decorators.py”, line 25, in _decorated
return func(request, *args, **kwargs)
File “E:\SeafileProgram\seafile-server-5.1.3\seahub\seahub\views\sysadmin.py”, line 183, in sys_repo_admin
per_page + 1)
File “E:\SeafileProgram\seafile-server-5.1.3\seahub\thirdpart\seaserv\api.py”, line 80, in get_repo_list
return seafserv_threaded_rpc.get_repo_list(start, limit)
File “E:\SeafileProgram\seafile-server-5.1.3\seahub\thirdpart\pysearpc\client.py”, line 110, in newfunc
File “E:\SeafileProgram\seafile-server-5.1.3\seahub\thirdpart\ccnet\rpc.py”, line 75, in call_remote_func_sync
req_id = self._start_service(client)
File “E:\SeafileProgram\seafile-server-5.1.3\seahub\thirdpart\ccnet\rpc.py”, line 36, in _start_service
raise SearpcError(“Error received: %s %s (In _start_service)” % (rsp.code, rsp.code_msg))
SearpcError: Error received: 511 Unknown service (In _start_service)
我把log日志发上去了,能否给看一下,是什么原因,谢谢
是底层的程序报错了,ccnet.log 和 seafile.log 中应该也有报错信息,你再发一下吧。
ccnet.log
[12/02/16 11:20:45] …/common/session.c(398): Accepted a local client
[12/02/16 11:20:45] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:20:45] …/common/peer.c(943): Local peer down
[12/02/16 11:21:35] …/common/session.c(398): Accepted a local client
[12/02/16 11:21:35] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:21:35] …/common/peer.c(943): Local peer down
[12/02/16 11:22:25] …/common/session.c(398): Accepted a local client
[12/02/16 11:22:25] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:22:25] …/common/peer.c(943): Local peer down
[12/02/16 11:23:15] …/common/session.c(398): Accepted a local client
[12/02/16 11:23:15] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:23:15] …/common/peer.c(943): Local peer down
[12/02/16 11:24:05] …/common/session.c(398): Accepted a local client
[12/02/16 11:24:05] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:24:05] …/common/peer.c(943): Local peer down
[12/02/16 11:24:55] …/common/session.c(398): Accepted a local client
[12/02/16 11:24:55] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:24:55] …/common/peer.c(943): Local peer down
[12/02/16 11:25:45] …/common/session.c(398): Accepted a local client
[12/02/16 11:25:45] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:25:45] …/common/peer.c(943): Local peer down
[12/02/16 11:26:35] …/common/session.c(398): Accepted a local client
[12/02/16 11:26:35] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:26:35] …/common/peer.c(943): Local peer down
[12/02/16 11:27:25] …/common/session.c(398): Accepted a local client
[12/02/16 11:27:25] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:27:25] …/common/peer.c(943): Local peer down
[12/02/16 11:28:15] …/common/session.c(398): Accepted a local client
[12/02/16 11:28:15] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:28:15] …/common/peer.c(943): Local peer down
[12/02/16 11:29:05] …/common/session.c(398): Accepted a local client
[12/02/16 11:29:05] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:29:05] …/common/peer.c(943): Local peer down
[12/02/16 11:29:55] …/common/session.c(398): Accepted a local client
[12/02/16 11:29:55] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:29:55] …/common/peer.c(943): Local peer down
[12/02/16 11:30:45] …/common/session.c(398): Accepted a local client
[12/02/16 11:30:45] …/common/peer.c(941): libevent got an error! what=33, errno=0 (No error)
[12/02/16 11:30:45] …/common/peer.c(943): Local peer down
seafile.log
[12/02/16 11:22:25] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:22:25] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:22:25] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:22:25] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:23:15] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:23:15] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:23:15] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:23:15] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:24:05] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:24:05] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:24:05] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:24:05] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:24:55] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:24:55] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:24:55] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:24:55] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:25:45] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:25:45] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:25:45] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:25:45] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:26:35] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:26:35] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:26:35] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:26:35] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:27:25] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:27:25] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:27:25] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:27:25] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:28:15] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:28:15] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:28:15] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:28:15] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:29:05] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:29:05] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:29:05] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:29:05] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:29:55] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:29:55] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:29:55] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:29:55] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:30:45] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:30:45] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:30:45] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:30:45] http-server.c(1915): Could not bind socket: No error
[12/02/16 11:31:35] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/02/16 11:31:35] …/common/mq-mgr.c(106): [mq mgr] publish to hearbeat mq: seaf_server.heartbeat
[12/02/16 11:31:35] listen-mgr.c(120): listen on port 12001 for block tranfer
[12/02/16 11:31:35] http-server.c(1915): Could not bind socket: No error
应该是windows系统的设置导致的seafile程序报错,具体原因不好说,可以重启系统,重装seafile都试试。
问题已经解决了。是系统的问题,我重新启动服务器,就好了,谢谢。
