用的是mysql5.7.18
自己搭建
搭建肯定没有问题 phpmyadmin没有报错 网站都可以正常运行
python默认
安装是按照官方的文档一步一步来的
用的是nginx1.12.0
conf文件也没有错误
重启服务器管用,但是几分钟之内立马提示Page unavailable
不管重启几次 都是几分钟内提示Page unavailable
在没有提示Page unavailable之前 文件夹文件等都可以正常上传 正常创建
搜索过论坛上没有类似的问题
想问一下如何解决
贴一下错误:
2017-05-25 14:25:14,406 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /api2/repos/
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/handlers/base.py”, line 108, in get_response
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/middleware/locale.py”, line 32, in process_request
request, check_path=check_path)
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/utils/translation/init.py”, line 198, in get_language_from_request
return _trans.get_language_from_request(request, check_path)
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/utils/translation/trans_real.py”, line 503, in get_language_from_request
lang_code = request.session.get(LANGUAGE_SESSION_KEY)
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/contrib/sessions/backends/base.py”, line 59, in get
return self._session.get(key, default)
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/contrib/sessions/backends/base.py”, line 181, in _get_session
self._session_cache = self.load()
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/contrib/sessions/backends/db.py”, line 21, in load
expire_date__gt=timezone.now()
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/manager.py”, line 127, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/query.py”, line 328, in get
num = len(clone)
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/query.py”, line 144, in len
self._fetch_all()
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/query.py”, line 965, in _fetch_all
self._result_cache = list(self.iterator())
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/query.py”, line 238, in iterator
results = compiler.execute_sql()
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/sql/compiler.py”, line 838, in execute_sql
cursor = self.connection.cursor()
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/backends/base/base.py”, line 164, in cursor
cursor = self.make_cursor(self._cursor())
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/backends/base/base.py”, line 135, in _cursor
self.ensure_connection()
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/backends/base/base.py”, line 130, in ensure_connection
self.connect()
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/utils.py”, line 98, in exit
self.connect()
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/backends/base/base.py”, line 119, in connect
self.connection = self.get_new_connection(conn_params)
File “/usr/Jonny/seafile-server-6.1.0/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/backends/mysql/base.py”, line 276, in get_new_connection
conn = Database.connect(**conn_params)
File “/usr/lib64/python2.7/site-packages/MySQLdb/init.py”, line 81, in Connect
return Connection(*args, **kwargs)
File “/usr/lib64/python2.7/site-packages/MySQLdb/connections.py”, line 193, in init
super(Connection, self).init(*args, **kwargs2)
OperationalError: (2003, “Can’t connect to MySQL server on ‘127.0.0.1’ (111)”)
2017-05-25 14:25:16,153 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /ajax/space_and_traffic/
num = len(clone)
self._fetch_all()
self.connect()
self.connect()
2017-05-25 14:25:17,435 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /profile/
num = len(clone)
self._fetch_all()
self.connect()
self.connect()
没人知道吗????????
1![]()
这里不是写的很清楚吗。
Can't connect to MySQL server on '127.0.0.1' (111)")
贴一下你的 ccnet.conf 注意隐去mysql的密码
