1、停止seafile.sh stop和seahub.sh stop
2、把seafile-6.0.7解压到haiwen下
pi@cloud:/usr/local/www/haiwen/seafile-server-6.0.7 $
3、pi@cloud:/usr/local/www/haiwen/seafile-server-6.0.7/upgrade $ sudo ./upgrade_5.1_6.0.sh
This script would upgrade your seafile server from 5.1 to 6.0
Press [ENTER] to contiune
[INFO] You are using MySQL
[ERROR] Failed to execute sql: Duplicate column name ‘wiped_at’
Failed to upgrade your database
更新数据库时出现问题。
还有一个问题是sudo seahub.sh stop停不下来服务,我现在是通过手动sudo killall python2.7把seahub的进程杀掉,希望能修改一下程序。
