Seafile 在 Centos7 中不关闭 SELinux 的配置
前言
seafile使用了nginx反代后,由于nginx受到SELinux的限制,无法读取用户生成的seafile里seahub的目录文件,故此需要修改seahub的上下文来使得nginx获得读取seahub的权限.
tail -f /var/log/audit/audit.log
type=AVC msg=audit(1478221314.101:84): avc: denied { read } for pid=1947 comm="nginx" name="seafile-server-latest" dev="dm-2" ino=11 scontext=system_u:system_r:httpd_t:s0 tcontext=unconfined_u:object_r:unlabeled_t:s0 tclass=lnk_file
type=SYSCALL msg=audit(1478221314.101:84): arch=c000003e syscall=2 success=no exit=-13 a0=124e640 a1=800 a2=0 a3=0 items=0 ppid=1943 pid=1947 auid=4294967295 uid=996 gid=994 euid=996 suid=996 fsuid=996 egid=994 sgid=994 fsgid=994 tty=(none) ses=4294967295 comm="nginx" exe="/usr/sbin/nginx" subj=system_u:system_r:httpd_t:s0 key=(null)
1. 开放nginx允许被访问
setsebool -P httpd_can_network_connect 1
2. 修改seahub文件上下文
ls -Z /seafile/seafile-server-latest/ |grep seahub
[root@localhost ~]# ls -Z /seafile/seafile-server-latest/ |grep seahub
drwxrwxr-x. 500 500 unconfined_u:object_r:unlabeled_t:s0 seahub
-rwxrwxr-x. 500 500 unconfined_u:object_r:unlabeled_t:s0 seahub.sh
修改前的上下文是unlabeled_t,nginx没有对他可读的权限故此需要修改seahub目录以及目录下所有文件为nginx可读.
chcon -R -t httpd_sys_content_t /seafile/seafile-server-latest/seahub
drwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 seahub
[root@localhost ~]# ls -Z /seafile/seafile-server-latest/seahub
-rwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 code-check.sh
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 CONTRIBUTORS
drwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 fabfile
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 HACKING
-rwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 i18n.sh
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 latest_commit
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 LICENSE-thirdparty.txt
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 LICENSE.txt
drwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 locale
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 Makefile
-rwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 manage.py
drwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 media
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 pylintrc
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 pylintrc.template
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 pytest.ini
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 README.markdown
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 requirements.txt
-rwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 run-seahub.sh.template
-rwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 send_user_notifications.sh.template
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 setenv.sh.template
drwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 sql
drwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 static
-rw-rw-r--. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 test-requirements.txt
drwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 tests
drwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 thirdpart
drwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 tools
seahub目录和seahub目录下所有文件都修改为httpd_sys_content_t的上下文,nginx就可以读取了.
3. 修改seahub-data上下文
但是发现自定义的logo依然无法显示,因为seafile为了方便用户自定义logo和css,将logo和css都放在了seafile-server-latest之外.故此也需要定义seahub-data的上下文.
[root@localhost ~]# ls -Z /seafile/seahub-data
drwxrwxr-x. 500 500 unconfined_u:object_r:unlabeled_t:s0 avatars
[root@localhost ~]# chcon -R -t httpd_sys_content_t /seafile/seahub-data
drwxrwxr-x. 500 500 unconfined_u:object_r:httpd_sys_content_t:s0 avatars
4.修改seafile-server-latest连接的上下文
经过上面三步依然存在问题,发现nginx无法通过连接seafile-server-latest读取.
这样,seafile就可以无需关闭SELinux也可以顺畅的运行了.
总结
其实就四条命令
