seafile6.0.5 环境centos7.2不能上传文件
seafile。LOG
[06/05/2017 03:29:14 PM] …/common/obj-backend-fs.c(309): [obj backend] Failed to create path for obj f5017083-cf89-4afd-b4e0-9883573833fc:27fce6a7f6ac509b0ab2203be32cab92c98e8662.
[06/05/2017 03:29:14 PM] repo-mgr.c(3160): Failed to add commit.
[06/05/2017 03:29:35 PM] upload-file.c(1947): [upload] Failed open temp file.
[06/05/2017 03:30:29 PM] upload-file.c(1947): [upload] Failed open temp file.
SEAHUB.LOG
2017-06-05 14:56:28,966 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 14:56:37,622 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 14:57:04,882 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 14:57:39,970 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:00:05,039 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:00:46,592 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:01:42,278 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:19:06,622 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:19:37,698 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:20:45,393 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:23:06,778 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:24:56,167 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:27:26,362 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:28:48,833 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:29:05,883 [ERROR] seahub.api2.views:573 post Failed to add commit
2017-06-05 15:29:14,367 [ERROR] seahub.api2.views:573 post Failed to add commit
seahub_django_request.log
2017-06-03 16:07:06,760 [WARNING] django.request:170 get_response Not Found: /news/ashnews.php
2017-06-03 16:07:16,822 [WARNING] django.request:170 get_response Not Found: /twiki/bin/view
2017-06-03 16:07:22,577 [WARNING] django.request:170 get_response Not Found: /bin/view
2017-06-03 16:07:27,793 [WARNING] django.request:170 get_response Not Found: /cgi-bin/twiki/bin/view
2017-06-03 16:07:31,023 [WARNING] django.request:170 get_response Not Found: /whatsnew.txt
2017-06-03 16:07:32,588 [WARNING] django.request:98 _reject Forbidden (CSRF cookie not set.): /
2017-06-03 16:07:32,891 [WARNING] django.request:170 get_response Not Found: /index.php
2017-06-03 16:07:33,327 [WARNING] django.request:170 get_response Not Found: /phpshowtime/index.php
2017-06-03 16:07:48,699 [WARNING] django.request:170 get_response Not Found: /AUX/.aspx
2017-06-03 16:08:17,512 [WARNING] django.request:170 get_response Not Found: /php/php.exe
2017-06-05 14:48:41,355 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /
File “/opt/cloudpan/seafile-server-6.0.5/seahub/thirdpart/Django-1.8.10-py2.7.egg/django/core/handlers/base.py”, line 132, in get_response
File “/opt/cloudpan/seafile-server-6.0.5/seahub/seahub/auth/decorators.py”, line 27, in _wrapped_view
File “/opt/cloudpan/seafile-server-6.0.5/seahub/seahub/base/decorators.py”, line 40, in _decorated
return func(request, *args, **kwargs)
File “/opt/cloudpan/seafile-server-6.0.5/seahub/seahub/views/init.py”, line 781, in libraries
create_default_library(request)
File “/opt/cloudpan/seafile-server-6.0.5/seahub/seahub/views/init.py”, line 736, in create_default_library
passwd=None)
File “/opt/cloudpan/seafile-server-6.0.5/seafile/lib64/python2.6/site-packages/seaserv/api.py”, line 69, in create_repo
return seafserv_threaded_rpc.create_repo(name, desc, username, passwd)
File “/opt/cloudpan/seafile-server-6.0.5/seafile/lib64/python2.6/site-packages/pysearpc/client.py”, line 112, in newfunc
return fret(ret_str)
File “/opt/cloudpan/seafile-server-6.0.5/seafile/lib64/python2.6/site-packages/pysearpc/client.py”, line 25, in _fret_string
raise SearpcError(dicts[‘err_msg’])
SearpcError: Failed to add commit
2017-06-05 14:54:12,661 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /api2/default-repo/
File “/opt/cloudpan/seafile-server-6.0.5/seahub/thirdpart/Django-1.8.10-py2.7.egg/django/views/decorators/csrf.py”, line 58, in wrapped_view
File “/opt/cloudpan/seafile-server-6.0.5/seahub/thirdpart/Django-1.8.10-py2.7.egg/django/views/generic/base.py”, line 71, in view
File “/opt/cloudpan/seafile-server-6.0.5/seahub/seahub/api2/base.py”, line 23, in dispatch
File “/opt/cloudpan/seafile-server-6.0.5/seahub/thirdpart/djangorestframework-3.3.2-py2.7.egg/rest_framework/views.py”, line 466, in dispatch
File “/opt/cloudpan/seafile-server-6.0.5/seahub/seahub/api2/base.py”, line 20, in handle_exception
File “/opt/cloudpan/seafile-server-6.0.5/seahub/thirdpart/djangorestframework-3.3.2-py2.7.egg/rest_framework/views.py”, line 463, in dispatch
File “/opt/cloudpan/seafile-server-6.0.5/seahub/seahub/api2/views.py”, line 3138, in post
repo_id = create_default_library(request)
passwd=None)
2017-06-05 15:16:57,247 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /
passwd=None)
2017-06-05 15:16:57,309 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2017-06-05 15:28:17,124 [WARNING] django.request:170 get_response Not Found: /favicon.ico
